How can I upgrade storage?
I have a Lenovo 100S Chromebook, serial number LR04HMFR if you need it, and I was wondering if I could, how would I go about upgrading my 16G storage to something like 120G.
Es esta una buena pregunta?
The hard drive for this device is actually soldered directly onto the motherboard. Unless you are very skilled with a soldering iron, it will not be easy to remove. I highly suggest simply just investing in an external hard drive if you are looking for more memory to store your files.
Fue útil esta respuesta?
step 1 undo the screw on the back
Step 2 gently remove the hard drive (it is silver)
Step 3 Unplug the cable from the hard drive
Step 4 put new hard drive in a reconnect cable
step5 put screw back in
step 6 you're done
No, impossible on this model, the memory is a chip soldered to the mainboard.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,439
