Help Finding Resistor and Capacitor Values on Logic Board
Hi folks!
I have a Mid 2012 MacBook Pro with Retina display (A1398, EMC 2512) that experienced some liquid damage. A small amount of juice got into the MacBook and completely burned out pin 1 on the internal DisplayPort connector, which I identified as the backlight power pin. (The data pins still worked and the computer still booted up fine, but the backlight was completely gone.) I was able to install a new connector but ran into some troubles. This was the first time I'd ever used a rework station, so I accidentally blew off an inductor, a QFN package, and 3 of the smallest capacitors and resistors I have ever seen. I was able to reinstall the QFN and inductor without too much hassle, but the very tiny components were blown to God knows where.
I lost half of these guys. (The ones handing on by a thread were both lost ) At this point I hope to remove all of these tiny components, clean the pads, and use solder paste to put on a fresh set in one go.
Here is the location of the components on the logic board:
(NOTE: multimeter probe for scale)
From right to left, the missing components are labeled as:
R9000
R9001
R9002
C9028
R9003
C9029
My question is as follows:
1) What are these component values?
2) What type of package do these components use?
3) Where's a good place to source parts like this?
Thank you in advance for your help!
Bunker
Es esta una buena pregunta?
