Nikon 5200 charger not working
Hi , I have Nikon 5200 camera.
Recently camera charger fall down and it stopped working. Can it be repaired?
Es esta una buena pregunta?
Vinayak Shindagi, The cable or charge port may be damaged. The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the camera to check the charge port,connections and other components for being loose/burnt/damaged. If not wanting to do the repair yourself have a good local camera repair shop have a look and estimate repair. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,118
1 comentario
Hi,
Have you tried checking if the there is any voltage on the terminals with a multi meter. I would suggest checking that first.
- de John Savio
