Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
El Mavic Pro es un dron compacto y plegable con capacidad de grabación de video 4K, lanzado por primera vez en noviembre de 2016. El número de modelo es M1P y su modelo de controlador es GL200A.
Left rear arm support replacement part?
I had a small crash that bent up a small plastic support piece for the left rear arm.
The drone still flies, but that rotor isn't flying parallel to the ground anymore (even with some duct tape support): https://goo.gl/photos/xxZGB68M9ZvfhDt16
top view and rear view (broken support is covered in duct tape)
I found Where to buy replacement parts, but I can't tell if this part is part of the middle frame, upper shell, or bottom shell since it doesn't look like it's connected to the top or bottom shell.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Alright, I figured it out. That piece is called the saddle, and it's connected to the arm.
I can't find anywhere to buy just the saddle, but by searching "dji mavic pro left rear arm" on ebay I found an entire arm with an intact saddle for $30 with shipping.
It looks like you can also buy them from Cloud City Drones, but they're out of stock at the time of writing.
Will update when it comes in!
2017-07-18 edit: it came in! Confirmed that that piece is part of the arm. Replacement was pretty straightforward - just a bunch of screws and minimal soldering. Some parts of prying the case apart were tricky, but nothing harder than an iPhone screen repair.
Fue útil esta respuesta?
Puntuación 3
2017-06-12 Update: those two side plastic parts that come with the middle frame aren't the same pieces. I'm still trying to track them down.
Figured it out as I was typing out the question.
These side plastic parts are part of the middle frame, which you can buy on ebay by searching "dji mavic pro middle frame". I found a middle frame with two side supports for $15.
I imagine it would be easy to 3D print this part - it's just a flat piece of plastic with a hole in the middle.
Puntuación 2
1 comentario:
Thank you so much! You just saved me hours of research. I just knocked my mavic pro out of the top of a 70' post oak with a dog ball thrower (that took awhile), and broke the left rear arm stop when I caught the drone. Going to look for a middle frame now!
- de Compartir
Añadir tu respuesta
Christian Genco estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 38
Todo El Tiempo: 4,489
