Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How do I fix the loose samsung chromebook plus bottom panel
I bought a Samsung chromebook plus and it has a loose bottom panel to the right of the touch pad,this originally occured as I removed the laptop from tablet mode,how do I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
You will need a PHILIPS Size 0 screwdriver to remove the back panel. You will have to remove the 8 screws on the back (there are none under the plastic feet), then you will need a plastic card so you can stick it between the body and the cover, then slide the card around the sides to pop them out, after that you can just separate the hinge-side of the panel from the body with your hands. However, putting the cover back on is much harder. iFixit Guide: How to disable the touchscreen on a Samsung Chromebook Plus
Skip steps 4, 5, and 6.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Baker Wadamba estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,409
