When I insert a blank dvd-r disc, the screen says it cannot dub
The screen says it cannot dub, because the disc is not compatible.
Es esta una buena pregunta?
If you are using a Panasonic dvd recorder you must first turn on 'high speed dunning's in the settings menu before you record the programmes. Only programmes recorded after this is enabled in settings will high speed dub. You can use 'flexible recording' to dub to dvd even if 'high speed ' is not enabled. The recorder will react a disc if something else is recorded on it and there is not enough room. Hope this helps mikeonfreeserve@hotmail.com
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 59
