Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
Es esta una buena pregunta?
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
Fue útil esta respuesta?
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,806
