What if water is poured into the keyboard
Water poured into the keyboard
Es esta una buena pregunta?
Take the keyboard apart and let the plastic keys dry out and clean the circuit board with 99%IP alcohol . If it was distilled water by some fortunate chance just let it dry out . Distilled water contains no contaminate minerals that will cause corrosion on the board ,but if its just tap water or bottled spring water take it apart and clean it with the IP alcohol. Do not under any circumstance put it in rice. Hope his helps
Fue útil esta respuesta?
It will generally short it out rendering it useless.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 54
