Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3786 Ver todo
Symptoms of Battery Failure
When I try to turn on my macbook with battery in, it doesn't startup. When its plugged in to charger, it turns on, then shuts down after few minutes. Without the battery and just charger it starts fine and I continue using it. Do you think the problems with the battery or with circuit that charges battery?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This all points to a bad battery- what is the model number of your Mac? If you give it to us I can then direct you to the proper part.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
My macbook pro 2012 has similar yet a different problem...my compute starts, but I wont hear the fan running or apple logo. After I shut it down and unplugged the AC plug and plugged it back, then it boots up but I wont see the apple booting still. I recently installed a new ssd and had no problem until now...could it simply be the battery being out of juice ?...besides, I did notice a message saying my battery needs a soon replacement so...thought ?
P.s: I opened the under cover and seen my fan running, just not strongly as usual, like it would on normal booting.
- de
My model is a Macbook pro 9,2
- de
Before going to the trouble and cost of replacing parts:
1. Verify that you have all updates installed, particularly Battery Update 1.4 (KB# HT3421)
2. Reset the SMC (KB# HT3964)
3. Reset your PRAM (KB# HT1379)
SMC Reset in a Nutshell
1. Remove the battery and AC power
2. Press and hold the power button for 10 seconds
3. Reinstall battery and power
Given this model's track record its probably the battery but SMU's do go on the fritz every now and again (plus resetting the SMU doesn't cost any green).
All MacBook batteries are the same so don't worry about getting your model number (ie. if you really wanted you could put a black battery in a white MacBook, dalmatian style).
Also Note
Selected battery issues are covered by a Repair Extension Program for which no model is eligible after 3 years from the date of purchase. Eligibility must be determined by an Apple Authorized Technician and repairs fulfilled at option by Apple.
Puntuación 1
1 comentario:
Model Number: A1881
MacBook 2,1
SMC Version (system): 1.13f3
- de
Añadir tu respuesta
Nash estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 9,651
