Popcorn not popping out of kettle
When the corn starts popping, some of it comes out of the kettle but then it seems that the unit that spins on the bottom stops and the popcorn continues to pop but is trapped in the kettle. I have to turn the unit off and use a knife to "pry" the popcorn out.
Es esta una buena pregunta?
5 comentarios
@carlie2017 what make and model is your popcorn machine. You checked the agitator and stirrer? what have you checked?
- de oldturkey03
Could you take some pictures to show us what you mean?
- de George A.
I Great Northern could not popping all kettle. It left over haft the kettle inthe pot? any one know how to fix
- de kongnightt
Can you replace the thermostat in a ccp399 Popcorn cart? Brand new Used for 8 pops and now will not pop?
- de happyonedeb
the possibility of the connector to the stem is not tight. when the corn seed begin to explode and have a load on the stem. the shaft does not rotate according to the motor. or your motor has broken. when the motor overheats it causes the motor to stop abruptly and spin again when it has cooled down.
- de Boo Hai Pan
