Saltar al contenido principal
Modelo: Dell Vostro 1440/1450/1540/1550 Fecha de lanzamiento: 2009
Preguntas 15 Ver todo
My motherboad is short curcuit
When i plug the power adapter into my laptop mother boad ... adapter light was get off ... and i unplug the wire within motherboad and ac current.. and then i plug again only to ac current then light geting lightup may can i get my mother boad schematic diagram...please...
Es esta una buena pregunta?
Puntuación 1
2 comentarios
@nsandanuwan check your power supply first. It sounds like it works for as long as there is no load on it. Once you apply a load to it, it seems to fail. As for a schematic, there are a few different logic boards for this Dell. You do want to open up your laptop and tell us what label the board has.
- de
processor cooling fan voltage not getting what problem may be
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@nsandanuwan if your power supply checks out okay you want to start with to measurements on the board. See attached image. Possibility is a failed component (we still need to get the proper board number from you) like a failed resistor.
Here is the complete DC schematic for the DV15HR board. You can use the test points as shown in the schematic to see where you have power etc.
Fue útil esta respuesta?
Puntuación 1
6 comentarios:
cooling fan voltage not gert
- de
@BHAGWATI PRASAD Joshi is this a question or an answer?
- de
cooling fan voltage not getting what is the cause rest circuit is ok
- de
@BHAGWATI PRASAD Joshi on your computer?
- de
cooling fan voltage not getting what is the reason
- de
Mostrar 1 comentario más
Añadir tu respuesta
Nirosha estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 496
