Saltar al contenido principal
How to open the speakers to switch the beadings?
The beadings of my speakers are porous and tearing apart. I'd like to switch these, because apart from that they're still in good condition.
Unfortunately I don't know how to open the speakers without damaging them. They got no screws or similar on the back side.
I contacted the Logitech support but they won't help me due to "security reasons". I think they just want me to buy a new Logitech system.
Does anyone have an idea?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@halloei, Christian, Check the video link below to see how to get inside the speaker., Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
UPDATE 04 14 2017 SPEAKERS
It looks like the speakers are attached to the face plate cover which may be tightly clipped or even possibly glued to the cabinet, possibly you can find a thin blunt object(putty knife) and carefully get under the edge and pry cover off. If it seems to be glued, try heat around(hair dryer/heat gun) the perimeter of cabinet/face cover to soften the adhesive pry carefully as you go.
https://www.youtube.com/watch?v=0_ul9P6U...
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
Thanks @lpfaff1 , I've found this video, too. But unfortunately he only opens the subwoofer and not the speakers.
- de
@halloei ,Christian, it looks like the speakers are attached to the face plate which may be tightly clipped or even possibly glued to the cabinet, possibly you can find a thin blunt object(putty knife) and carefully get under the edge and pry cover off. If it seems to be glued, try heat around(hair dryer/heat gun) the perimeter of cabinet/face cover to soften the adhesive pry carefully as you go.
- de
The face plate was attached to the cabinet with a double-sided tape. Thanks @lpfaff1 for your help!
- de
Christian, Happy to hear you got it, thanks for replying back and good luck on your repair.
- de
Añadir tu respuesta
Christian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 4,544
