Saltar al contenido principal
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
How do I change front struts
How do i change front struts
Es esta una buena pregunta?
Puntuación 0
1 comentario
jms_skw ,You are putting your question in the answer box, it would be best for you to repost all vehicle details year,make,model, etc and your question/problem as a (question)! This will be seen by more volunteers and may assist answering your question better.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Front struts are easy on a caravan and do not require a front end alignment when done as long as you don't change the tie rod ends when you do it . There are tow bolts holding the strut at the bottom and 3 on top accessed through the engine compartment. If your only replacing the strut then you will require a spring compressor as you need to compress the spring to remove it safely This video will help
https://www.youtube.com/watch?v=ns_IzhfJ...
Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
jms_skw estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 112
