Saltar al contenido principal
Encuentra soluciones a tus preguntas sobre reparación de ordenadores.
Preguntas 21219 Ver todo
Ground loop - is that the problem and how to fix it
I have what I suspect to be ground loop. The 3.5mm cable between the line in on my PC and the line out on my monitor is producing a strange buzzing noise. I've tried removing the ground connection between the two, but it didn't help. What I'm really looking for is verification that the problem is really ground loop.
Recording of sound:
https://drive.google.com/file/d/0BxmOW-d...
Supposed solution:
https://www.amazon.com/gp/aw/d/B019393MV...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario:
Anybody got any ideas?
- de
Agregar un comentario
1 Respuesta
hello George A. did u fix these buzzing noises ? was it ground loop ? did that mpow ground isolator solve that ? im asking because i have same problem right now
Fue útil esta respuesta?
Puntuación 0
1 comentario:
No, I didn't buy the ground loop isolator but if you have the problem you should try that. I didnt buy it because I found another solution: to not use a 3.5mm connection.
- de
Añadir tu respuesta
George A. estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 189
