Saltar al contenido principal
Modelo núm. A1367 / Capacidad de 8, 16, 32 o 64 GB
Preguntas 915 Ver todo
How to remove the circle gray spots in the screen of iPod?
Has gray circle spots in the screen and the edge of the circles has a yellowish color.
- how to removed that without opening the iPod touch? And also without deleted the files inside of the iPod touch?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Solución Elegida
It is a defective LCD, it had developed grey spots and unfortunately you will have to open it up to fix it.
Fue útil esta respuesta?
Puntuación 2
OK. I have one of those gray spots. In fact, I had two, a large one (about the size of a penny) and a tiny one. They appeared after my 5 year old daughter sneaked a while with the ipod. I had accepted she should have hit the screen an so it was a dead spot. I could keep using te ipod, so I did nothing. Yet, after a few months, the small spot disappeared. So, the screen spot wasn't really a dead spot. It came back to live. Now, a month later, the large spot started to move on its own. It has moved almost a quarter of an inch. That is, a good part of the screen that I had assumed dead is now working perfectly well (I can now see the battery status, which I couldn't with the original spot location). Unfortunately, it is moving towards the center of the screen, rather than outwards, as I would like it to. I wonder if someone had seen this before, and whether there is a way to make it move the way I would like it to? It actually seems to be moving downwards, since te ipod is mostly standing on a charging cradle.
Puntuación 2
1 comentario:
Hope this video helps. It helped me remove spots from my Sony tablet. https://www.youtube.com/watch?v=PxUOlqaN...
- de
Those are dead spots in the digitizer. You are going to need to replace the screen assembly. You won't lose any files by doing this.
Puntuación 1
2 comentarios:
The digitizer is the touchscreen, that does not make any sense.
- de
l,;lhljmklghljg;lhlgl.h.lgljlgv.jll,b,cf,lbhnfb ngbngvnfjngnmfnmbgn
- de
I've moved the grey spot around, there where tons of small ones on the screen after a sharp drop of my phone, then I started to move them around until a big grey dot has formed at bottom -left of screen, the size of home screen button, although I'm not able to push it out of the edge., ( the spots become more fluid like when heated, and solid and bit compressed when cooled, used a heat gun and fridge) any suggestions on pushing it out? I'm using iPhone 4,
Puntuación 1
Añadir tu respuesta
khatee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 34
Todo El Tiempo: 15,175
