Upgrade bluetooth on Mid 2012 Mac Pro?
So I bought a refurbished Mac Pro 2012 and discovered that it's not Airdrop compatible (specs are below).
I actually thought all 2012 models were fine ( ? ) but otherwise is it possible to upgrade the wireless/bluetooth chip to a newer one?
My old 2008 Mac (years ago) came without one and I spent an hour or so fitting it for wireless after buying the kit on eBay so I'm thinking maybe I can swap out the chip in this 2012 Mac for a newer model that's compatible with LE support (and thus Airdrop)
- Address: 8c-2d-aa-2c-1e-b3
- Bluetooth Low Energy Supported: No
- Handoff Supported: No
- Instant Hot Spot Supported: No
- Manufacturer: Broadcom
- Transport: USB
- Chipset: 2046
- Firmware Version: v208 c518
- Bluetooth Power: On
- Discoverable: Off
- Connectable: No
Es esta una buena pregunta?
4 comentarios
The actual bluetooth works fine, I've been using my bluetooth headphones with it fine. I think it's just the wrong firmware. The advert said "Bluetooth 2.1 + Enhanced Data Rate" and the firmware says "v208 c518" but I think I need a newer chip like your "BCM43xx 1.0" - as I said it was refurbished and I suppose it had a general bluetooth chip put in rather than one that necessarily worked with the more modern AirDrop standard.
Presumably I need to buy a new bluetooth/wireless chip and install it, at least I can eBay the existing one though. If there's any ideas for a specific card or ebay/etc links then that would be great.
- de Calvin Graham
@danj knows more about these than I do.
- de mayer
Sadly, the older Mac Pro's don't offer the needed Airport card for Hand Off services : Use Continuity to connect your Mac, iPhone, iPad, iPod touch, and Apple Watch & System requirements for Continuity on Mac, iPhone, iPad, iPod touch, and Apple Watch
But AirDrop services are supported! Use AirDrop to send content from your Mac
- de Dan
I upgraded a 2008 Mac Pro (sierra) with a tiny BCM94360cdax card and HandOff is supported and Airdrop. You have to connect 3 wifi antennas to J0, J2, J3 and Bluetooth antenna to J1. Don't forget to reboot twice to enable Apple bluetooth drivers
- de Comitéquartier Ouest
