Saltar al contenido principal
El portátil Toshiba Chromebook 2 se lanzó en 2014 y el número de modelo es CB35-B3340. Este Toshiba Chromebook es plateado con una pantalla de alta resolución de 13.3".
Preguntas 24 Ver todo
The screen keeps flickering, and at times goes entirely black.
The Screen on my Toshiba Chromebook 2 has recently started flickering and going black for a few seconds. When hooked into an external display, the external display works perfectly. Do you believe a replacement screen will fix this problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
my chromebook is lenovo 500e and my screen flickers sometimes and it scares me i think its the music im playing right now is causing it
- de
Mine is a hp Chromebook and I have tried resetting mine and now instead of better it's worse and it's now starting new every time I turn it on someone please help
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Yes, It should as it sounds like a bad cable. See if you can find a display cable on ebay for cheap and if you cant, try to find a broken one of these chromebooks without a broken display and transplant it as it will probably be cheaper then a new screen.
Toshiba Chromebook 2 Display Replacement
Fue útil esta respuesta?
Puntuación 2
Are you on developer channel? Try changing channel to stable, apply power washing setting, then update and restart
Puntuación 0
1 comentario:
mine is brand new i have tryed like 5 displays and it still does it
- de
I had a similar issue. In addition, sometimes it would go very dark, but with some difficulty be almost readable. The backlight was definitely still on. I also noticed the back of the display got almost too hot to touch. I ended up replacing the screen and this fixed the issue.
Puntuación 0
its the display plug o the screen has come loose and if you bump it you will see the screen will flash then go black take it to a tech place and the can just plug it back in for you, it happened to me too on a school chromebook.
Puntuación 0
Añadir tu respuesta
Ryan R estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 56
Todo El Tiempo: 8,714
