Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Apple AirPods son auriculares inalámbricos lanzados en diciembre de 2016.
Why is my Airpod case not turning on or connecting to my phone?
I got Airpods in early March and they've been working and feeling great. I dampened them with a moist towelette which might be the problem. I charged them overnight, but it the morning when I opened the case the small light did not light up green, orange, or white and my phone did not connect to them automatically or manually. It may be a charger cord problem. The outlet was doing well with other devices.
Es esta una buena pregunta?
Puntuación 17
23 comentarios
that is the same problem with my airpods
- de
Same problem is happening to me right now
- de
Same problem
- de
A mi igual que hiciste dime por favor
- de
That’s the same thing that happened with mine
- de
Mostrar 18 comentarios más
Agregar un comentario
25 Respuestas
Solución Elegida
If you haven't tripped possible LSI (liquid submersion indicators) and voided the warranty, take them to Apple and request a repair, they are under warranty. You will void the warranty if you try to repair them yourself. If Apple turns you down, then your warranty has been voided and it doesn't matter if you attempt a repair.
Fue útil esta respuesta?
Puntuación 6
8 comentarios:
It’s water damage get a new case
- de
How do I buy a new case
- de
You can buy a third-party replacement on Amazon for $15-40 or buy a replacement straight from apple or an apple seller. Apple replacements cost $70, but there is no risk of damaging your AirPods, and they are fully compatible with the AirPods. Though third-party charging cases are cheaper, you should be safe, research the product, and most importantly, read the bad reviews of the AirPod case to help gauge its potential risks.
Link for Apple's Replacement:
https://www.amazon.com/Apple-Wireless-Ch...
Link For a third-Party Replacement I trust (YOU SHOULD ALSO RESEARCH IT YOURSELF):
https://www.amazon.com/dp/B0842QKMYX?pd_...
- de
I have this problem but it isn’t that the case isn’t charged, the case won’t work until I plug it in. Once it is plugged in it will tell me that it’s 95% and then charge my air pods.
- de
same problem.Did you find any solution yet?
- de
Mostrar 3 comentarios más
Respuesta Más Útil
HERE’S THE SOLUTION THAT WORKED FOR ME!
My AirPods were 100% dead. No green/amber/white light, nothing. I had a full battery from the previous day, so it made no sense whatsoever.
  • Tried pressing/holding the reset button. Didn’t work.
  • Tried plugging in the charger. Also, nothing.
  • Got the AirPods off the case, repeated the process. Nope, still not working.
  • Finally, I placed my AirPods on the wireless charger I use every once in a while. 1 second later, the green light shows up. My AirPods are back to life.
It ended up being a weird bug. Good luck to everyone else!
Puntuación 10
9 comentarios:
Wow, it came on after I used my wireless charger too
- de
The AirPods were fully charged and plugged into computer. Next morning I turn the PC on and it says USB device not recognized. Came to find that it doesn't light up anymore and AirPods cannot be connected to. The thing needed to sit 5 seconds on the wireless charger and it turned on. Thanks man!
- de
Strange but worked for me too!
- de
Only wireless charger is working to charge my case but that’s fine!! Saved me from buying a new case generic or from Apple.
Thank you!
- de
It worked perfectly fine. Awesome!
- de
Mostrar 4 comentarios más
*Get another AirPods case and charge YOUR AirPods units in another case to determine if your case, or either AirPod is bad.*
Do you have any friends that have AirPods? If so ask them if you can put your left and right unit in their case. If both of them charge you'll know they are not the problem. The problem likely lies within the charging case. You can buy another case from Apple for around $70.
If your AirPods don't charge in another case then the problem likely lies with the AirPods. If they do charge I suspect your charging case is to blame.
Puntuación 3
1 comentario:
You should also try the other person airpods in your case to see if your case if fine.
- de
Basically throw them out the &&^&^$^ window and get a new pair…. No im joking i have encountered an isssue in which the case is determined to be at a status of being dead, and even when put on charge there is no way the case is turning back on. Honestly will consider returning item. I will try fix tonight and if i do i will update you guys. Its just pretty $@$*!& that after 3 months, £200 bluetooth headphones can &&^&^$^ go through so many errors. Tbf it well feels like i have been &&^&@@ over by Apple but will find solution and update
Yours truly, Callum
Add snapchat @ziegcal if you can update me on a solution.
Puntuación 3
Guys, I'm having this problem too. My airpods were just acting normally untill one day battery drained to 0 and now I can no longer use them. When I plug charger no response. No light. No sign of life. Zero. Zilch. Nada. Can you guys help me out? Is there anything promising or they are finally dead?
Puntuación 1
4 comentarios:
Have you fixed it yet? Mines doing the same and I just got them 1 month ago!
- de
I KNOW HOW TO FIX!
you need to plug your AirPods in to a power outlet
then connect to WiFi enabled phone/iPad
leave for 5 mins
and the FireWire is updated and should be working fine
you’re welcome :)))
- de
I don’t get it please explain more I want to fix them
- de
Same Like may AirPods where fine till I forgot to charge my case and it went dead but I still had a AirPod in then that one died so I put everything thing back in the case and I charged them for 8+ hours and I held the button down this morning and it wasn’t turn on I never put them in water or anything can you help idk how to fix them and I just got these just 5 months ago
- de
This might sound ridiculous but for me it worked when I pushed the top lip of the case forward when opening. This might not work for everyone but it was like magic for me.
Just push on the back of lid and push it up at the same time.
Puntuación 1
3 comentarios:
Oh my god , thank god , my earpod is really fix , i did thesame thing , thanks ?
- de
Holy $@$* it worked I can see the light now wtf how
- de
How tf did this acc work
- de
I think you have to press button on the back of the charging case. The pairing with the iPhone part I don’t know.
Puntuación 0
I’m having the same issue, but after having them for 2 years- so there’s no recourse for a guy like me. I’ll need to eventually break down and get a new set. The headphones are randomly disconnecting and the case is randomly not lighting up, even though all are charged well over 20% most times.
Puntuación 0
I KNOW HOW TO FIX!
  1. you need to plug your AirPods in to a power outlet
  2. then connect to WiFi enabled phone/iPad
  3. leave for 5 mins
  4. and the FireWire is updated and should be working fine
you’re welcome :)))
Puntuación 0
4 comentarios:
This worked for me.
Thanks
- de
How do you connect with a WiFi device when it doesn’t come on at all even when charged
- de
Same question as Dora
- de
My AirPods charging died and thereafter when I charge them I see a green light and then after when I open the AirPods box I does not show light but when I plug them in my airs I automatically gets connected . When I try to rest them I don’t see any amber light . Can anyone please fix this problem
- de
Yep, I accidentally put mine through the washing, and well the case isn’t lighting up at all and I can’t even use the thing to check the percentage because they won’t connect to my phone because the button isn’t working either. Don’t want to buy another one truthfully even though I love them ever so much. Just charging them overnight and seeing what happens in the morning.
Puntuación 0
1 comentario:
did it work ?
- de
My led indicator won't work without a charger do you know how to fix that
I already reset them
Puntuación 0
2 comentarios:
This is the same issue I have. airpods and case work as expected but only if the case is tethered and charging. If unplugged, no charge for the airpods and pairing is sketchy.
- de
I am also experiencing the same issue. My airpods and the case work and the led light turn on only when the case is tethered and charging. When unplugged, there is no led light on when the case is opened. My airpods work, but not for long, since there is no indication of how charged they actually are.
- de
i have the same problem, my sister used them in the shower when i told her not to. now my mom has to repair them and they wont show the light or wont connect to my phone. i wouldn’t recommend putting them with any water.
Puntuación 0
2 comentarios:
Yo is she retarded hahahahaha tf
- de
soo hilarious
- de
I had the same thing happen. Mine are working now, what i did is i took the airpods into another case by Blackpods.
Then took them out again, looked on my phone to see that they were connected.
Then i put them into the original apple airpod case.
Then i charged the case with the airpods inside
And then it worked like normal.
Puntuación 0
1 comentario:
What if we don't have a different case during COVID-19?
- de
Having the same issue. But I put the airpods into another charged case and it instantly killed that charge case!!!
HELP!!!!!
Puntuación 0
This happened after my AirPods went through the clothes washer. In other words they got wet. The only way I found to make them “work” again was to fully recharge the case and the pods, leave them plugged into the lightning cable, then pair them to whatever device. If the case is ever unplugged, they won’t be able to pair.
Puntuación 0
Guys my case light turns orange when i plug it in to a charger for about 8 secons, i left it for about 2 hours and the case hasnt been charged..has anybody got a solution about this ?
Puntuación 0
yall my airpods are completely dead but its fully charged and after almost an hour of research I just found the same things over and over again. I had them connected to my iPad and my android phone but it stopped working so I just “forgot” the device and now when I press the back button to pair them back there is no response but it still connects to my computer. help. srs. I'm gonna die.
Puntuación 0
1 comentario:
Same thing for me
- de
I was using my airpods and I haven’t charged them for two days, while I was using them both airpods disconnected and I thought it was because the case was low battery (the airpods itself still had battery left), didn’t really think much of it until the next day I tried charging it and there was no light popping up, left it on for a few hours and still no light, cleaned the port, took out the airpods, tried resetting it but no luck. It’s been a couple of days now and I’m at the point of giving up
pls help me!!
Puntuación 0
I used my airpods yesterday to the gym and today I wanted to used them but notice the light was off. I thought it was the battery so I charged them but still noting. I try to reset them but they won’t turn on. I have leave them charging for almost 2-3 hours and still noting.
I don’t understand they were working perfectly fine and now they don’t. what should I do?
Puntuación 0
2 comentarios:
Try putting both earpods to the box and close it tightly like hold it in some seconds maybe its lossin inside then charge it back , like my earpod now not connected to phone if not connect to charger , hope it will work for you .
- de
This legit worked omfg hahahahaha this the solution really just keep the lid open while charging with cable
- de
my airpods light will not glow green but when charged will show amber. when i try to pair them the white light only flashes 5 times and it wont pair to my laptop or phone or anything.
Puntuación 0
my airpods had the same problem , i let them die and then the next day wouldn’t charge , jus an amber light then i resettled like they said then when i did that my airpods was not connecting to my phone at all so then outta no where it turned off then there wasn’t no light so then i jus read these comments then plugged my airpods into a charger then held down the case tight and it started charging then i tried to connnecg them still wouldn’t work then i jus resetted my phone and now it connects buh make sure ur phone is connected to wifi
Puntuación 0
AirPods only work if I have them on wireless charger and half open them to connect then I use them throughout the day without disconnecting them or putting the back in the case until I want to charge them again. Not a fix but a solution to use them.
Puntuación 0
My airpod is not connecting with my phone
Puntuación 0
Since your AirPods got damp with a moist towelette, that's likely the culprit for the current issues. Here are some steps you can try to get them working again:
  1. Let them Dry Completely: Moisture can damage the internal components. Leave the AirPods and charging case open in a well-ventilated area for at least 24 hours. Don't use a hairdryer or put them in rice, as that could worsen the situation.
  2. Clean the Charging Contacts: Gently remove any debris or moisture from the charging contacts on both the AirPods and the case. You can use a dry cotton swab for this.
  3. Reset the AirPods: Even after drying, a reset might help. Place both AirPods in the charging case and close the lid. Then, open the lid and press the setup button on the back of the case for 15 seconds, or until the LED light flashes white. This resets the connection.
  4. Check Your Phone's Bluetooth: Make sure Bluetooth is turned on and your phone isn't connected to any other devices. Try forgetting the AirPods in your Bluetooth settings and then re-pairing them.
  5. Update Software: Outdated software can sometimes cause connectivity issues. Update your phone to the latest version of iOS and check if there are any firmware updates available for the AirPods (usually happens automatically when connected).
If none of these steps work, then the moisture damage might be more severe. In that case, it's best to contact Apple Support for further assistance. They can diagnose the problem and advise you on repair options.
Puntuación 0
I have followed every step
Restarting Phone
Restarting AirPods
Updated Software on Phone
No moisture
Cleaned contacts with cotton swab
Forget Device
AirPods will not connect to Phone - cannot pair because the device won’t show in Bluetooth setting - just twirls, does not connect
Puntuación 0
Añadir tu respuesta
[deleted] estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 67
Ultimos 30 días: 277
Todo El Tiempo: 277,559
