Why is my computer not charging?
My computer is working fine but it's showing that is not charging and the computer is still on, but if i unplug the charger the computer shuts down. I don't know what is going on???
Es esta una buena pregunta?
First, I would recommend checking if the outlet that you are using is working. Maybe try a different outlet. If that doesn't work I would recommend trying a different charger or charging cable. That might work. If it doesn't, then you may want to consider replacing your battery.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 250
