Saltar al contenido principal
Una tableta desarrollada por HP en 2011 con la plataforma webOS. Cuenta con una pantalla de 9.7" y está disponible en 16 o 32 GB. La reparación es sencilla, pero requiere tiempo y persistencia.
Display problem in middle of display
My display has developed a 2" bar across the middle that is all garbled or fuzzy meaning you can't read or see what is supposed to be there. Otherwise the unit works well. Is there a way to fix this problem? Thanks in advance for any help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
likely the pins in your LCD connector are likely built up with dirt. Open the device, remove the LCD connector. use a toothbrush and 99%isopropyl to scrub at bot the gold traces at the end of the flex, and inside the female connector of the board. Air dry for 10 minutes, and reconnect.
This SHOULD Fix your issue.
If it does not, either the flex is damaged, or the connector on the mother board is damaged.
-if the flex is damaged, replace the LCD
-if the connector is damaged, remove the connector, and solder a new one onto the board. (This last step is a more difficult procedure, and without SMT Soldering experience, i would suggest taking it to a professional.)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Peter Mather estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 159
