New 3DS XL Home button not working.
New 3DS XL Home button not working anymore, Do I have to start tearing it down?
Es esta una buena pregunta?
Yes, you need to buy a new home button and install it. If you have a bit of experience taking things apart it shouldn't be much of a problem. If you're not that confident you can also take it to a repair shop/send it to Nintendo. If it costs more than 20$, try to get it cheaper somewhere else because the replacement part is about 3$ and it would take me about 5min to fix it...
Fue útil esta respuesta?
First of tell which smartphone use? One of the most common reason to android home button stopped working is system OS update or screen replacement. Sometime software key problem or home button not working is the common hardware problem after update OS. People annoying when home or power button not working, they press home button hardly to get respond but doesn’t work.
You can try below two methods in your android device.
1. Factory reset android phone
2. Wipe cache partition in android
Click here to show above methods step by step guide with screenshots and instruction.
this is a 3ds not a android phone
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 41
Todo El Tiempo: 2,375
