My phone is black screen
When I put it on the charger it jumps but shows nothing and take it off it's still black and can't hard reset or soft reset cause I have tried it don't know what to do
Es esta una buena pregunta?
Remove the battery and clean the terminals with ip alcohol. While you have the battery out test it with a multi meter . Check your results with the specs on the battery . You may need a new battery. Hope this helps
Fue útil esta respuesta?
What is the meter that you are talking about
@laurenalex A multi meter is a meter used to test voltage and continuity. If you are unfamiliar with it then have someone who is test it for you . how old is the phone and has the battery ever been replaced?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 98
