Saltar al contenido principal
Información de reparación para el iPod shuffle de cuarta generación. Lanzado en septiembre de 2010. Número de modelo: A1373.
Preguntas 29 Ver todo
iPod shuffle 4th generation plays a song repeatedly
I have an ipod shuffle 4th generation, when i try to play songs on shuffle it repeats only one song. how could i fix this?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Check the button position:
The top three way switch has three settings, on, continuous or shuffle. Green shading on the switch
indicates iPod shuffle is on, the next click over is continuous play, then the next tick after that should be shuffle.
Check the playlist:
It's possible you're stuck inside a specific playlist in the iPod, to change playlists you should be able to use the voiceover button. From the manual "Press and hold the VoiceOver ( ) button. Press Next/Fast-forward (‘) or Previous/Rewind (]) to move through the playlist menu. Press the VoiceOver ( ) button or Play/Pause (’) to select a playlist. Press and hold the VoiceOver ( ) button again to exit without making a selection."
Here's a pdf of the manual to help! Good luck!
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
apurva estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 4,463
