Saltar al contenido principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How replace power button
please help how i can repair button phone dont turn on
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
I need help to find where to get a new power bottom for Asus Zenfone 2
- de
You can get it on Aliexpress.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2 Motherboard Replacement
Fue útil esta respuesta?
Puntuación 2
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Puntuación -1
1 comentario:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
- de
Añadir tu respuesta
Anton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 4,042
