Saltar al contenido principal
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
Preguntas 12 Ver todo
No charge no ink
My dymo keeps flashing low battery sign but I just changed the batteries also I have it plugged into the wall charger I believe this is also causing it to not print probably everything works like it should except there is no writing on the labels once they print out.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Respuesta Más Útil
MAGGIE , You could try another compatible charger as it may be faulty. Clean the battery contacts in machine using a pen with an eraser on he end as it is a little abrasive or a Qtip dampened with 90% Isopropyl Alcohol or better, clean the terminals well and then blow out the dust/debri and change the batteries out for some new good quality batteries and try. Good luck.
Fue útil esta respuesta?
Puntuación 4
In case someone else googles this like I did. I figured it out shortly after. My colleague had inserted a couple of the new batteries the wrong way. Check the direction of the batteries and it should fix this problem.
Puntuación 0
I had the same problem. I rechecked how I installed the batteries and sure enough 2 of them were put in the wrong way. Corrected this and labels are printing correctly now.
Puntuación 0
On mine I have checked the batterys a few times but it still won’t print, the machine is brand new but there is no ink, the baterys are new and good
Puntuación 0
Añadir tu respuesta
MAGGIE estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 62
Todo El Tiempo: 5,890
