Saltar al contenido principal
Google Pixel es el primer teléfono insignia de Google, lanzado el 20 de octubre de 2016. El dispositivo con pantalla AMOLED de 5 pulgadas viene con opciones de almacenamiento de 32 y 128 GB y está disponible en tres colores; Very Silver, Quite Black, y Really Blue.
Preguntas 104 Ver todo
No sound on video shooting
No audio sound while playing a video captured using the phone camera, a muffling sound comes ! Microphone is perfectly fine as all other things are working well regarding nicrophone, i even tried shooting through whatsapp camera app and snapchat app but same results !
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
what phone? have you installed any new apps?
- de
Google pixel and no haven't installed any new apps ! I even booted my phone in safe mode, the problem still occurs .
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Try a factory reset, it sounds like a software problem. If that doesn't fix it go to google, they might be able to help. If not get a iPhone
Fue útil esta respuesta?
Puntuación 2
Google Pixel has three different microphones. The main one located next to the USB-C charging port is used for making calls and voice commands. The "camcorder mic" is independant, so perhaps it is malfunctioning (Google is replacing phones because of this, is a known factory issue).
Did you try sending the video to another device and watch it there? Is the video without audio or your device fails to play the audio of that video in particular?
Puntuación 1
This is a known issue with a weak solder joint on the Audio codec chip. A reflow of the chip will usually work, sometimes a reball maybe needed. Google are aware of this issue and were offering replacements last year to those effected. If you need more info let us know.
Puntuación 0
2 comentarios:
Could you do a follow-up post with a diagram of where the chip happens to be, and how we can go about reflowing it?
- de
HOw do I retrieve the audio from the video. Can I still reach out to google to get the replacement?
- de
Añadir tu respuesta
Ruchir estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 3,005
