Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Touch screen not working after battery replacement?
I just replaced the battery on my iphone 5s. I was extremely careful but this is my first iphone repair. My phone boots up just fine and I even received a text, however, my touch screen is completely inresponsive . Should I just check all cables? Could these mean I mixed up screws? I am definitely in over my head on thus one and this will probably be my last self repair.
Es esta una buena pregunta?
Puntuación 5
2 comentarios
I replaced,soldering very carefully, the battery of my Conquest S8 phone and the touch screen stopped working.The phone boots up fine , everything seems ok ,key lock occurs ,and all the other keys are active but I can not even turn off the device because the touch screen is not working , I can not unlock the keys to do anything even turning off.
- de
I had the battery of my Iphone 7plus replaced and my touchscreen was messed up and was jumping all over the place. Vodacom calibrated the screen and it was worse than ever. I took the simcard out and put another one into the phone to go to Vodacom and then the phone was working fine.
So if you are having problems after battery replacement, and touch screen jumping, take your simcard out and put it back in again. It worked for me. Very, very weird I know!!! No one can tell me why.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
The 5S can be tricky if you don't keep track of the screws. On the Screen Bracket, they are all of different sizes and differing only by 0.1 mm. So if you put a longer one in the wrong place, you can certainly cause some major problems. Do a search on Long Screw Damage to learn more.
You also need to disconnect the battery before disconnecting the screen otherwise you can blow the backlight circuit. However, your problem is touch related. I would carefully remove the screen (see my note on the battery above) and visually inspect the connectors for debris, damage or missing components in the surrounding area. Then re-assemble and test.
Then get back to us with more details and we can guide you from there.
Fue útil esta respuesta?
Puntuación 4
6 comentarios:
I looked up a few things about long screw damage and my phone does not have a blue screen- the display is as it should be. Occasionally I will see a minor line or something faint on the display.I was very careful with the screws so i'm hoping to rule that out. I will take it apart soon and reassemble all connectors and let you know if anything changes- thank you.
- de
Thank you so much! I disassembled, cleaned the connector area, reassembled, and the screen now works and any weird screen lines are gone.
- de
Thank you, some jack leg at Experimac replaced my battery and jacked up my phone. I couldn't figure out what the heck was going on! Saw this, checked the screws, they were in the wrong place. I put them in correctly and Boom! Screen is working again! Saved me a lot of money! Cheers to you.
- de
No love here. No signs of any damage or debris in the connectors. I've re-seated them multiple times and cleaned them using alcohol. Nothing I've done makes any difference. The phone powers up just fine, all the buttons, including the home button work just fine, but the touch screen does not respond in the least. Really wishing I had simply lived with the degraded battery at this point as this is now looking like this is going to force me to buy another used 5S. Very expensive mistake trying the iFixIt battery replacement.
- de
Replaced my iPhone 5s battery and weird lines are also appearing which screws should I check specifically
- de
Mostrar 1 comentario más
I’m having this same problem also.
After battery replacement, iPhone restarts randomly and I experience ghost touches. This ghost touches will stop for a while when I press the sleep/wake button then occurs again.
Sometimes if I put on data and play music same time, it will reboot. Kind’f like any change of power output drawn from the battery causes it to restart. I’m thinking it’s a faulty battery. Please wat re ur thoughts
Puntuación 0
1 comentario:
I had this issue too after replacing battery. However, i figured it was one of the connectors under the diaplay shield. Took the 4 screws off again and took all 3 connectors out and started again. The bottom/top left one wasnt in right...very fiddly but finally got it intonplace with a satisfying click, put the other 2 back in and reassembled phone and it all worked fine
- de
Añadir tu respuesta
Lindsey Bates estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 59
Todo El Tiempo: 34,460
