How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
Es esta una buena pregunta?
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 328
1 comentario
What is "tucking" and can you elaborate more on your problem
- de Cameron
