Saltar al contenido principal
Modelo A1311 / mediados de 2010 / 3.06 y procesador Core i3 de 3.2 GHz o procesador Core i5 de 3.6 GHz
Preguntas 342 Ver todo
What is the best option to upgrade?
Hi,
I have 21.5" iMac (Mid 2010) 3.06GHz Intel i3 with 4 GB of RAM
My question is: What is the best option to upgrade:
  • Replace the HDD to a SSD
Or
  • Increase the memory to 8 or 16 GB
Appreciate your help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The easier of the two is adding RAM as there is a door at the bottom which you can access to plug in the new modules.
As far as storage how about either adding the SSD as a second drive if you don't use your optical drive. Here's how: Installing iMac Intel 21.5" EMC 2389 Dual Hard Drive This way allows you to use a smaller cheaper SSD as you aren't trying to use it for storage but more as a boot drive and to hold your apps. Then use your current HD to store your stuff (docs, picts, music...)
If your HD is to small or failing I would look at going with a hybrid drive (SSHD) these have a fast SSD cache yet also have deep storage of a traditional HD gaining the benefits of both technologies.
For myself I would add the RAM at least getting the system to 8 GB and add in the second drive (SSD here).
Fue útil esta respuesta?
Puntuación 4
1 comentario:
totally clear and helpful
Thanks a lot, really appreciated
- de
Añadir tu respuesta
Sabir estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 123
