Saltar al contenido principal
Modelo A1419 / EMC 2806 / Finales de 2014 o mediados de 2015. 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 finales de 2015 / 3.3 o 3.5 GHz Core i5 o 4.0 GHz Core i7 (iMac17,1) Todo con pantallas Retina 5K
Preguntas 573 Ver todo
Need to upgrade the RAM
My iMac is running out of RAM now.
I spec'ed my Mac out when I bought it and yet my Mac is sucking the RAM up! I use so much it's not funny and I need to upgrade to 64 GB so this is not a answer to the question i need to know if you can put 64 GB in the iMac
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Some people have had issues with the first versions of the 27" 5K displayed iMac's running with more than 32 GB of RAM. So if you have one the first versions I would recommend you stick with 32 GB even if someone tells you it can be boosted to 64 GB.
Heavy RAM use can be due to what you are doing or it can be caused by a misbehaving app or two. So I wouldn't jump on putting more RAM into a system until you've verified you really need it.
How about running Activity Monitor app which is in your app utility folder as well as look at a good memory monitoring app like: Memory Clean2. Can you give us a clue on what you are doing as we might have some ideas how to be more effective here.
I do recommend having a SSD as the boot drive and making sure it is not over loaded with junk (at least 1/3 free). While this seems to be outside of RAM it really isn't. You see your system leverages the boot drive for virtual RAM and caching/paging within the app. So having fast and available space on the boot drive is important. While some people use a Fusion Drive we've moved to dedicated drives (basically, breaking the fusion drive set to there discreet drives). Size of the boot drive can also matter. Someone working on large images. video editing or music composition needs more space.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
facebook estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 108
