Squeaking sound on take off.
On take off I have revolving sqeak under car for about 25-50ft.
Es esta una buena pregunta?
Kent Gillespie, Probably a bad U joint, other possibilities brake caliper not releasing, ebrake/wheel cylinder sticking, bad wheel bearing,worn bearing in rear end, suspension bushing dry, fan/pwr steering belt, etc.etc..I have even had tire with low air pressure squeak. Have a good mechanic take it for a test drive to confirm or diagnose. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 119
