very slow while starting
it is taking to much time to start my iMac.
Es esta una buena pregunta?
It sounds like you need to do some TLC on your drive:
Other things that can help is add more RAM if you can with your system. If you have a traditional HD consider upgrading it to a hybrid (SSHD) like this one: Seagate FireCuda but be careful here as these drives only work in SATA III (6.0 Gb/s) systems if you have an older SATA II (3.0 Gb/s) you'll need the older series. The other option is to upgrade to a SSD drive like this one: Samsung 750 EVO SSD which will work in either a SATA II or SATA III system but the larger drives do get a bit costly so make sure its a wise investment given the age of your system.
Fue útil esta respuesta?
Shamaun xrry about that,it has problems with the operating system, gentle cleaning is needed or delete inactive services to create room for the machine to run faster.
Tonny entebbe uganda
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 62
1 comentario
How about telling us your exact model you have as there are issues on some versions of the 21.5" systems that can effect things here.
- de Dan
