How do I remove an ASA dial from Fuji Film Fujica ST605N camera?
How do I remove a ASA dial from a Fuji Film Fujica ST605N camera?
Es esta una buena pregunta?
The ASA dial is screwed down by a single screw in the middle of the dial. Using plastic rod or wood dowel that is just the same diameter of the head of the screw which then has a piece of rubber attached to its end you can fashion a friction screwdriver to unscrew the slot-less screw.
Here is the service manual for the camera: Fujica ST605 service manual it's exactly the same as your ST605N.
Fue útil esta respuesta?
Thank you I will let you know if this works. Thanks for pointing me in the right direction
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 44
Todo El Tiempo: 1,140
