Can I put a single cab transmission into a extra cab truck?
both trucks are 94 rangers both have same motor is the transmission going to match up with the driveline or will i need the driveline off single cab?
Es esta una buena pregunta?
94 and 95 had Two transmissions for this truck A4LD which was with an overdrive and a 4R44E which was used till 2000 They both will work for you but you do need to measure the tail stock . As long as the tail stock are the same length then you wont have a problem.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 175
