Saltar al contenido principal
Guías de reparación para el MacBook Air, la línea de Apple de laptops para consumidores.
Preguntas 4823 Ver todo
My computer is typing the letter z constantly
my computer is typing the letter z constantly. I can barzely type this letter!z I took the key off, nothing is stuck. I reset the czomputer. It was an intermittent przoblem, but now seems permanent. Also, the letter z does not type when I press the keyz
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
2 comentarios
I have the same issue with z key. What was the problem with yours? Did you get fixed? How much was it to fix. Please share any info you have. Thanks.
- de
i too havze this probzlemz.z funznyz is that it onzly types this letter after czertainz other letters: mz nz bz vz cz xz andz other letters are finez
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
It definitely sounds like the circuits responsible for the z key are started to ground, causing it to be seen as permanently pressed down by the system. This could either be a fault in the keyboard (which is most likely), or could be a motherboard issue. I would first try and clean out the connector - if it's still pressed down, then run the computer with the keyboard unplugged, and see if the issue persists. If yes, then it is a motherboard issue. If no, then it is an issue with the keyboard.
Fue útil esta respuesta?
Puntuación 1
Try removing the back of the Macbook and disconnecting the keyboard from the logic board. Then connect a removable keyboard via usb. If the problem no longer occurs then you need to replace the keyboard of the macbook.
Puntuación 0
I plugged in an external keyboard and it worked then tried laptop keyboard and it works now too!
Puntuación 0
I have the same problem on my macbook air 2015 model. How to fix it pleasee help my Mac condition is really nice idk why it is happening ?
Puntuación 0
Añadir tu respuesta
Andrea estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 63
Todo El Tiempo: 10,950
