Front Wheels will not turn
Toro lawnmower Model 20353. Front wheels will not rotate. Front axle will not turn either. Is front transmission bad?
Es esta una buena pregunta?
Denis O'Connor , This is a fairly new model and may still be under warranty and if is can be repaired/replaced under warranty. The problem could be a few things, the belt may have came off, debri or belt may be jamming drive pulley from turning, small drive gear may be jamming in wheel, faulty transmission, etc. Find below a parts brake down/Transmission and Front Wheel Drive Assembly pg.12, that may aid in dismantling the front drive system so you can inspect/diagnose and repair the problem. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 108
Todo El Tiempo: 2,547
1 comentario
This is a four wheel drive mower. Rear wheels turn and drive but cannot use the mower since front wheels resist movement.
- de Denis O'Connor
