Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Anunciado - 2014, noviembre El Samsung Galaxy Core Prime (G360, G361) funciona con un procesador de cuatro núcleos a 1.3GHz y viene con 1GB de RAM. El teléfono incluye 8 GB de almacenamiento interno que se puede ampliar hasta 64 GB mediante una tarjeta microSD.
samsung charger port wont work
charger port wont charge
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
soul524 have you tried a different cable and a different charger? Does it charge when you "wiggle" the cable in the connector? Does the connector looks damaged?
I have noticed that you have three questions related to the charging port. Are all of these questions related to the same phone?
replace charger port on samsung
How much is it to replace my charger port
and the current one
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
soul524 the charging port is soldered to the motherboard. you will have to disassemble your phone and replace the port. This video is almost identical to the way you will have to repair your phone. Replacement ports are available at places like this.
Fue útil esta respuesta?
Puntuación 2
La respuesta fue originalmente a otra pregunta.
soul524 around $10USD if you buy the ports from places like this. Use this video for your repair.
Puntuación 2
1 comentario:
@oldturkey03 , Just thought this was a little strange, maybe was it to be addition to your original answer?
- de
From my experience the core prime has a slightly different micro USB port, there is a raised section in the port which requires a charge cable with the corresponding relief.
Or the port is totally dead
Puntuación 0
I will be getting an android phone but the charger port is blown how can I get it fixed
Puntuación 0
Either look up YouTube videos and do it yourself or take it into a nearby cellphone repair place.
Puntuación 0
Añadir tu respuesta
soul524 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 1,756
