Saltar al contenido principal
Guías de reparación y soporte técnico para los iMac Intel 27" de Apple, presentados en octubre de 2009.
Preguntas 3405 Ver todo
iMac 5K Late 2015 SSD Replacement Troubles with Step 35. Urgent help.
I was following this guide on disassembling my Late 2015 iMac 5k 27".
Reemplazo del circuito SSD del iMac Intel 27" Retina 5K Display
I got to Step 35 to remove the 4 T10 screws. I have the Classic Pro Tech Toolkit (before the revamped one came out) and I was trying to remove the bottom right 7.3 MM T10 screw, but have not been able to give the screwdriver enough torque to get it out. I have tried many many times trying to get this screw out, but it is really in there. I ended up stripping the screw (by using so much force) and ruining the T8 head that came with the toolkit (although it says it's a T10 screw, it's actually a T8 because the T8 fits like a glove).
I am completely lost on what to do. I was trying to disassemble the iMac to fit a blade SSD in there and was not expecting to encounter a problem like this. I use this computer at work so I screwed myself over a little.
If anyone kind enough could please advise me on what I can do to rectify the issue I would sincerely and greatly appreciate it.
Thank you!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
A large jewelers pin vise should be able to clamp on the external wall of the screws head.
You'll likely need to use a large soldering iron (50 watt) or heat gun to heat the screw to soften the thread seal which they use.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Federico Olmedo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 117
