Saltar al contenido principal
Guías para la versión LTE del iPad Mini 2. Anunciado el 22 de octubre y lanzado el 12 de noviembre de 2013. El iPad mini 2, originalmente conocido como iPad mini con Retina Display, tiene todos los píxeles del iPad Air en una forma más pequeña de 7.9 " factor.
Why is there no charge port replacement walkthrough?
I'm replacing the charge port on the ipad and there's no tutorial which sucks. I don't know if I should connect the new port on the back of the motherboard a specific way, please help!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Felix. That's because it requires micro-soldering.
Micro-soldering flexes is tricky because you can easily melt the flex so this is really beyond what a DIY fixer should handle. If you have the tools and skills to do this kind of work, then you don't really need an iFixit guide ;>).
Look for an experienced micro-solderer in our area.
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Thank's! I found this out, currently trying to learn defiantly not ready haha. What's the best way to go about learning how to micro solder?
- de
There are lots of great videos on Youtube. Ultimately, ill need a good quality temperature controlled soldering iron and hot air station, flux and good tweezers and go from there.
- de
Añadir tu respuesta
Felix Robinson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,081
