Front camera blurry and light leak from top corner after screen repair
I just repaired an iPhone 6 and used an iFixit front panel full assembly, screen worked fine however in the dark I noticed heavy light leak from the edges and also the front camera was blurry. Any suggestions as to a cause of this problem? And what is the recommended solution?
Thanks
Es esta una buena pregunta?
Blurry front camera. Clean front camera lens and glass cover.
- de Ben
is the frame bent regarding the light leak?
- de richard
No, the frame is not bent at all.
- de Stelios Sgoutas
I get the same light leakage from beside the volume buttons nearly every time, I've tried checking for bends in the frame, I even used new frames and OEM parts but it still happens. Am I doing something wrong?
- de S2i
