How do I fix my touch screen
My screen doesn't recognize when my finger is touching how do I fix this? Is it a calibration thing?
Es esta una buena pregunta?
Usually when the touch stops working its cause by the digitizer failing. One of two things has probably happened . You dropped your phone or your phone got wet . either way you will need to take the phone apart and either check to see that the digitizer is properly connected to the motherboard or if it is connected properly. it means the digitizer is done and you need to replace the it.
this video will help with the replacement
https://www.youtube.com/watch?v=CJtVKlmE...
You can get a complete display for less than $50 here
http://www.ebay.ca/sch/i.html?_from=R40&...
Hope this helps
Fue útil esta respuesta?
try replacement screen and let us know that is usually the problem
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 5,952
1 comentario
I purchased a replacement screen assembly. Put it in (a serious pain in the butt) reassembled, screen works, no touch response. Did it twice. No dice. The new ribbon for the screen seems to be a tad off on the new part. Causing it to no lay flat if it is going to make the connection. Could the replacement be mid-manufactured?
- de John Bryant
