Can I have my monitor screen replaced
I had water spilled, keyboard works fine, originally screen was OK.
But now I can barely make out display images because it is dark.
Is it possible to have my monitor replaced? It appears as though rest of computer works fine.
Es esta una buena pregunta?
Puntuación
0
Does it work with an external monitor?
- de mayer
@danielsani may not be an LCD issue but a backlight issue. Let us know what you get when you connect an external monitor
- de oldturkey03
Yeah, it is most likely a backlight failure if it was caused by water damage, as the display is sealed and elevated from the rest of the laptop, whereas the backlight circuitry on the motherboard in close to vents etc. The LCD backlight operates at a high voltage so is a common point for liquid damage.
- de https://vancouvermac.ca
