Only One side lifts
Two of my propellers detached on landing after reattaching, drone lifts from one side only. Can't fly, looks like I'm grounded, what do I do?
Es esta una buena pregunta?
Hold your drone up to eye level, amd turn all 4 props so that the face horizontally (blades facing left to right, so u can see all of the blade, not facing front to back) then make sure the front left prop looks just like the back right propeller, thusly, the front right will match the back left prop. Ive run into the issue of one side lifting iff and the other not doing it, which leads to a flip one way or the other. Making sure the propellers are in the correct locations fixed it
Fue útil esta respuesta?
It worked perfectly! Thanks, so much!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 214
