Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Repair guides and support for self-balancing two-wheeled electric scooters, sometimes incorrectly called hoverboards. These boards are manufactured by many companies under many different names, but are virtually identical in construction.
Charger broke off in the charger port! Any idea on how to get it out?
The charger broke off in the charger port and was wondering how I could get it out?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
@ebane0314 You should post an image so we can see what you are working with
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
When we went to charge it it broke off
Fue útil esta respuesta?
Puntuación 1
1 comentario:
same bro mine was a jetson rogue
- de
Charger what broke off? The plug? If there was enough force placed to break it off, I'd say the internal receptacle is most likely damaged as well.
One trick I use to get plugs out is to get some Silly Putty. Squish it into the plug, then quickly yank. It might not come completley out, but it should get it out far enough to get some tweesers or needlenose pliers in there.
Other than that, without a pic showing exactly what's going on I can't really give a more detailed answer.
Puntuación 0
2 comentarios:
@kentucyranger I have the same problem but this site doesn’t allow to post a pic
- de
Oh wait I figured it out - pic is below I think the charger broker off in the port
- de
Ver contenido de la imagen:
Puntuación 0
Añadir tu respuesta
Erica estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 2,742
