How to disassemble LS6191/LS6195 base unit of the VTech retro phone
Found 3 screws on bottom of base unit. Even after removing these, I am not able to open the base unit in order to fix the LCD display that is missing some of the lines. Does anyone know how to open the base unit? Is there a service or repair guide/manual available that shows teardown?
Update: There are two other screws underneath the rubber feet in the front. Removed these. The case must have tabs keeping the two halves held together. I started opening on one side but I did not want to break anything so stopped.
Es esta una buena pregunta?
1 comentario
Would you mind supplying some pictures? Anything and everything you can. Perhaps make your own teardown?
- de Jackson
