Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un teléfono con Windows conocido por sus capacidades de cámara. También conocido como Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
Can I repair the rear camera without replacing it?
the rear camera did not work before and I replace it but within less than three months the new one is not working. the problem is that the focus is not working so the picture is blurred and if I try to take a picture of a note or a page of a book, the only thing I can see is the lines without being able to recognise even a letter.
Is there something that I can do?
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@nusha , nuha, you could disassemble and check and clean the connections, also make sure the camera is locked into the correct position and see if that helps, if not you may have to replace the camera.
Below are a couple links to your device, they will show how you can get inside phone to access camera. 1st link is tear down of device, 2nd link is service manual. Also I posted links to a couple forums that trouble shoot your issue, If you google your Nokia Lumia 1020 camera not focusing problem, you will see there is a lot of info. out there. Good luck.
Nokia Lumia 1020
http://devdb.ru/data/file/file5245f74f49...
https://forum.xda-developers.com/lumia-1...
http://forums.windowscentral.com/nokia-l...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
nuha estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 624
