Saltar al contenido principal
La Brother MFC-240C es una impresora de inyección de tinta a color todo en uno.
Preguntas 20 Ver todo
MFC-240C does not print - despite fresh cartridges and multiple purge
My Brother MFC-240C prints in black, but in none of the colors. I have already installed new original Brother ink cartridges, and executed multiple Normal/Power Purge runs (using the Maintenance Mode as described in the service manual, chapter 9 / 9-43). The problem persists.
Can anybody help? Has anybody successfully disassembled the printer, and cleaned manually the ink supply tubes and/or the printing head?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Print head could be clogged and needs some cleaning. Check Youtube for videos on cleaning...Ink have expiration too, it could be old and dry.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thank you for your suggestion. It is absolutely correct. I have disassembled the entire printer with the help of a detailed service manual for MFC-240C. This is necessary as the print heads of Brother inkjet printers are located deeply inside the printer. Cleaning the printhead with distilled waters, followed by some purge operations (in the printer's service mode) helped.
All colours appear again perfectly. My old printer got a second life :)
- de
You are welcome. Where can I see the service manual for MFC 240-C, I hope you don't mind?
- de
Añadir tu respuesta
Markus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 2,100
