got screws all mixed-up hard to reassemble
is there a screw size chart for that device?(3gs) and how do I get it?
Es esta una buena pregunta?
there are tons of video on youtube when you put in the search bar "dissasembly / assembly" and your device name.
usually are HD videos, so it can help you identify your screws. had similar issue with some screw from iphone 5, just take the smallest and go for the smallest holes, screw and turn around. if they don't fall out, it's probably the correct diameter. try to @%^!* the length depending on the place where you put it. closer to the case is smaller screw.
Fue útil esta respuesta?
Download the IFIXIT APP it will tell you step by step instructions and each screw size. A micrometer will be handy
@davey3t , David check the links below from ifixit Replacement guides, a lot of the screws are identified in the assy. of the 3G. Good luck.
iPhone 3G Rear Case Replacement
iPhone 3G Logic Board Replacement
more guides for 3G below.
Guía
Dificultad:
Moderado
Guía
Dificultad:
Difícil
2 - 3 hours
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 412
