Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías para la tableta Sony Vaio Tap 11. Anunciada el 4 de septiembre de 2013 y lanzada el 18 de octubre de 2013. Número de modelo SVT112A2WL. La prima delgada, elegante y atractiva de la Surface Pro 2.
Where is the CMOS battery?
My system clock keeps on delaying compared to the actual time.
Is there a repair?
I also noticed that it may be caused by the CMOS battery starting to fail.
I have opened the device up and am comfortable, as I replaced the mSATA myself.
However, I don't really know where the CMOS is.
Where is it? Thanks
Update (01/01/2017)
Imagen
Tried to locate it in the area, but it looks like it isn't really there.
It's only cables that connect the circuit board.
Also, I purposefully disconnected this part that is mentioned in the instructions for motherboard replacement and speaker replacement. The computer turned on and wifi was completely functional with it disconnected. What is it for?
Imagen
Imagen
Es esta una buena pregunta?
Puntuación 0
1 comentario
akihiko1639 post some clear images of your complete board (may take multiple shots) and post those with your question.
the connector is for your speakers.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Imagen
Imagen
The blue bit that can be seen is probably the RTC battery.
The images were taken from the Vaio Tap 11 teardown by Sony on Youtube.
Hope it helps!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
akihiko1639 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 3,164
