Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La única versión wi-fi del iPad Air de Apple, número de modelo A1474. Disponible en Space Gray o Silver, incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
Home button only replacement?
So, a few months ago my iPad's front screen was shattered, and also came off. I was very annoyed, and since I was in an agitated state, I peeled the middle section off, leaving glass on the inner edge of the screen. My father and I recently sat down with an iFixit replacement kit and repaired the screen. However, I could not recall where the previous home button was, but I am just going to use guided access until then. I wondering what needed replacing, where I'd get the part(s), and if I need to buy adhesive and open the screen again. (I currently have a piece of foam taped over the empty spot, just to keep it covered.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Yes. You'll have to apply new adhesive, if you take the new display off. Yeah, I would put the home button on, and then center the home button cable and ribbon over the hole on the new glass digitizer
Here's a guide, just in case. You shouldn't need to buy a new one, just play with how to install the old one
Reemplazo del conjunto del panel frontal del iPad Air Wi-Fi
Fue útil esta respuesta?
Puntuación 3
8 comentarios:
Ok, so do I just need to buy the home button from the parts store? Do I also need a bracket?
- de
You will need the Home Button, bracket and cable if you dont have them. I would also recommend replacing the adhesive after removal. Also, be very careful as the screen can very easily crack when you're removing it. Time and patience is your friend here.
- de
Oh, I'm sorry. I was confused. I didn't realize you lost the home button. Yes, you will need to buy a new home button flex cable, and a bracket. Holger Keuster is right on both accounts. Be careful, when removing the new glass. It can be broken quite easily
- de
Just gonna finalize some things before I go to ordering, I am sure that nothing has happened to the cable for the home button, just that the button itself came up with the screen and I misplaced it. I need a flex cable, bracket, and they just go under the screen over the place where the button would go?
- de
Yes, if you've lost the parts, from the old display, then you need to buy the new ones, and put them where the old ones were
- de
Mostrar 3 comentarios más
Añadir tu respuesta
williambivan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 792
